Adaptator LTM to M
Oscar,
You can find the adapters at most online photography sites, as well as eBay. Since your R has manually selected frame lines it doesn't matter which M adapter you get. Some of the cheaper adapters on eBay do not have the additional machining that is needed to pull up the proper frame lines on the Leica M cameras, but they should work fine on your Bessa R.
