Adapter Ring
Burkey
4:17 PM
Hi Folks - I'm about to purchase the 21mm Skopar lens. Am I correct in assuming that the "M-Bayonet Adapter Ring for 28mm & 90mm Screw-Mount Lenses" Voigtlander makes is the correct ring to buy to go along with this lens? I'll be using it on my RD-1 and occasionally on my "T". Thanks in advance.
. . . Burkey
any ring should work, the different rings just bring up different frame lines automatically on a Leica M series camera
Any screw to M Bayonet adapter will work with the R-D1. The different versions only apply to Leica M cameras as the tabs on them set the required framelines in the Leica viewfinder. The R-D1 has manual switching of framelines and for a 21mm you need an external finder in any case. Just avoid really cheap adapters as these sometimes can introduce focus problems. Leica or VC should be OK.
Posted sametime as above!
