Adding grain?
Lightroom 3 Beta 2 has a Noise adjustment slider, looks god awful (forgot to mention that in the Lightroom thread the other day..)
martin
interestingly enough, I find Lightroom3 noise to be rather good, although, I admit, looks right only if applied with pretty high values, and then downsized, it's not really believable when printed, but ok, still better than digital noise normally present at high ISOs...
Is this in Lightroom or Photoshop or something else?
You don`t just add grain. Pick color or mono, small, or large, soft or sharp, then use "blend if" to keep grain out of shadows and highlights . Split the sliders with the alt key or command key to make smooth transitions. Then adjust the opacity of that layer to suit.
I defy you to tell it from real film.
Back when I started the thread LR3 hadn't been out yet. Now I also use LR3 for grain and love it.
While the thread continued being mostly about grain in b&w pictures, I started it to inquire about adding grain in a color photo. Unlike most I usually don't add grain in order to get a grainy picture. I'm not after the 35mm grain look. What I do is add just a little bit of grain to give the image a subtle texture and 'hide' the pixels.
If I do any kind of cloning or spot removal I apply the grain only after I'm done retouching.
