ADOX new englarger
dogbunny
Registered Boozer
7:19 AM
Via ADOX Facebook page I see they came out with a multiformat enlarger. It comes with at least 3 different film holders and it is described as a "double condenser" enlarger. They are asking just under 200 euros for it. I'm seriously considering it because I typically shoot 35mm and 120 6x6. It seems a pretty we'll thought out enlarger.
This will be my first darkroom set up. I'll only be printing B&W.
What do the more seasoned darkroom gnomes think about this?
A link to their Facebook
Thank you.
db
Looks like a very basic design, quite old-school. If you're serious about the darkroom I suggest looking for a higher-grade enlarger on the used market. Don't know about where you are, but in the States you can't give darkroom equipment away and there are amazing deals to be had.
A good enlarger should have a solid support and the means to adjust the lens and negative stage for alignment. Also, double condenser-type illumination has the tendency to give higher contrast and less subtle tones in the print and will show negative flaws like dust and scratches much more than a diffuser or cold-light setup.
Pretty amazing that they would come out with a new enlarger at this point in history.
I should point out that for less than that price I got a used B & W enlarger in very good condition with a good lens, so I agree with Saul.
Randy
Excellent news indeed - this clearly proves the analog photography is not fully dead afterall but showing clear signs of stabilizing and finding it's own niche.
Hats off to Adox.
Margus
Looks alike a Krokus-enlarger which was built since I don't know when in former Czechoslovakia. I used one years ago for a long time, a very reliable and simple "machine" for max. 6x6 cm negs.
I'm 99,9% sure, that this is a rebranded version of the Paterson Universal enlarger.
At least for those, who I usually call "serious hobbyist" (for the lack of a better word), this seems to be true. See the last paragraph in this article.
http://www.amateurphotographer.co.u...per-maker-on-mission-to-double-photo-printing
What types of used enlargers will support multiple formats like the above enlarger? I don't need to have a brand new enlarger, but I'd really prefer one that supports 35mm and 120mm 6x6.
db
db
I just got a Saunders 6700 with color head, which will do 35mm or medium format. But you need to get the appropriate negative carrier.
Many other makes will also accommodate a range of negative sizes.
Randy
I think Adox must have found found an attic packed with new enlargers from the 70s, and they figure they'll turn them over to the film crowd.
Exactly. Nothing new here except the box. Still, they must be getting enough inquiries to make them think it was worth doing.
OP: look for a Beseler 23C. Two girders, very solid, does up to 6x9. And being given away. Or the Omega B22.
