N
Nick R.
Guest
TXT=Tri-X? I haven't tried that with HC-110, only Tmax3200 pro. But I'm not surprised at Tri-x looking good at any speed. It's a great film.
kaiyen said:Dave,
Now _that_ is what I'm talking about! Nice work. It's nice to see such great results in a situation that really, really cried out for pushing.
fyi - grain is the result of the emulsion's grain structure (a grainy film can't be less grainy than the graininess of the film, exposure, dev time and dev temperature. I am pretty sure it's overexposure that makes it grainier - that's why people go for the thinnest neg than can get (different standard of "thin" than what you got, of course). So the underexposure itself didn't increase the grain, but the looong time in the developer did. And "long" is relative to the developer - using a really active developer for a short amount of time would have yielded a lot of grain, too, since that developer would usually be used for a much shorter amount of time.
allan
aizan said:so you exposed at 4500 and developed for 12,800? why not develop for 4500 and increase contrast while you print? wouldn't you get less grain and risk of blown hilights?
Nick R. said:TXT=Tri-X?.
kaiyen said:Dave,
Oops. I missed the information about overexposing by 1.5 stops, even after rating at 12800. That is about 4500, as aizan points out. Your results are still very impressive, but that explains the nice shadow detail, regardless.
The reality is that, if you're pushing any film beyond 3200, you aren't going to be spot metering the shadows anyway. And no developer out there will give you that much speed, so the idea of doing actual speed tests out at that EI range is kind of ridiculous. So it comes down to aesthetics, really. For instance:
http://www.kaiyen.com/photos/gallery/albums/film tests/txt/normal_rodinal3200.jpg
vs.
http://www.kaiyen.com/photos/gallery/albums/film tests/txt/normal_microphen3200.jpg
Is comparing Rodinal vs. Microphen. The ultimate result of my test is that you can get similar results re: shadows, midtones, and contrast control between the two developers. But forget about speed - zone III is just gone, and there isn't enough exposure to get a zone I density reading. So it's about look.
Anyway. I hope to try out rating TXT at 12800 and shooting with no exposure compensation. let's see how it comes out...
allan
