Hello. I have a number of Agfa's I'm sure there must be someone around that works on them but the cost is probably more than an old camera is worth. Two of the Karat's I currently have suffered from Agfa lube lockup. A detailed fix is on the web (facebook I think) mine now work, simple tools are required. Patience's is also needed. I will say it feels pretty darn good when you fix it yourself. It's likely you'll see it's much simpler than you imagined
