air photography
jorisbens
rff: penguins know why
5:21 AM
Belgium, the beercountry
If i want to make a photo of (mostly) the sky, with a lot of blue air and some white clouds, and I use centerweighted metering. How many stops should I approximately adjust the reading for good exposure. And how many stops for a sky with very big clouds varying from white to very dark gray?
I can understand that this might be a difficult question, but some rules of thumb would be very useful.
If it is a blue sky with some white clouds, then set the exposure using the sunny sixteen rule. A heavy cloudy day with very big clouds varying from white to very dark gray, I would go with the suggested reflected light meter reading. If you are using colour or B+W negative film, it doesn't hurt to give an extra stop of exposure.
Hate to disagree with everyone, but Sunny 16 does not apply to taking a photo of the sky, only taking a photo when the sky is sunny with open clouds - very different!
Meters are designed to give proper exposure when measuring something that is called 'middle grey'. That's an 18% grey card, available at camera stores. If you meter off very white fluffy clouds, you get underexposure - the clouds will come out grey and the blue sky will be dark. If you meter off of the blue sky, I have no idea what you will get - depends on the shade of blue - it might meter as a good 'middle tone grey'.
I agree that bracketing would be a good idea. I would also not shoot with color-print film, it usually renders blue sky with a lot of gunk in it. I've never liked skies with color print film of any kind - marginally better with color-print film and a polarizer. B&W does a fine job, and so does most slide film. But both have less exposure latitude than color-print film.
I would take a meter reading of several different points in the sky - from darkest cloud to blue sky to fluffy white cloud and average them - add all the f-stops together and divide by the number of readings you took, using the same shutter speed. And then bracket like crazy too.
Best Regards,
Bill Mattocks
Here in the Midwest between 10 am and 2 pm a clear blue NORTH sky will give a reading similar to an 18% gray card. For predominatly white clouds you would want to give about 1 1/2 to 2 stops MORE exposure than what your averaging meter is reading. For dark stormy black clouds 1 1/2 to 2 stops LESS exposure than your averaging meter reading. Avoid having the sun in your frame when taking your meter reading as it will give you grossly underexposed results.
Just my 2 cents.
Wayne
P.S. For Black & white film a yellow no. 8 or 15 filter will increase your contrast for the clouds to show up. A no.25 red or 29 red filter will dramatically increase contrast.
I'm pretty certain about this:
Sunny 16 setting with render blue skies medium grey, and fluffy white clouds white. Set the camera manually referencing the film speed in use, ignore the built-in reflected light meter (which may be fooled by the white clouds.)
An overcast day containing a range of white to very dark clouds (info from original post) would average out to medium grey, so go with the built-in reflected light meter, or open up a stop from that reading.
Thanx for the advice, I think i will study the "art" of air-photography by shooting different skies with a lot of bracketing and I will post the results on RFF when I'm finished. 🙂 (This might take a few weeks because of my recent project and my exams) And i will post the best shots in the gallery so everyone can enjoy them 😛
Joris
