Albinar Canon FD - trigger aperture blades?
kevin_v
5:36 PM
San Francisco Bay Area
Hello everyone. I picked up a lens at the Salvo this afternoon. It's an "Albinar ADG 28mm 1:2.8 macro" for the Canon FD mount. Glass looks clean, but I can't figure out for the life of me how to release the aperture blades... anyone know a bit about the FD mount?
(I don't have a FD camera, but I figured if I could get the aperture blades to go, I could hack it into some other use.)
Edit/Append:
Attached is a pic
You need to mount it on a camera to release the blades. Alternatively some sort of lens rear cap which allows the breech ring to rotate far enough.
I suppose an adapter for FD to some other mount such as m4/3 would also work.
Ronnie
I managed to manually release the breech ring, however neither of the levers sticking out the back do anything even once it's turned – I think one's related to AE, but the other...
Well, anyway, after a night of fiddling, I'm pretty sure it's broken. And as you said rxmd, it's probably not a super great lens. I might keep fiddling with it, but I don't think I'll pour any money in it to get it fixed. Thanks guys.
As someone else pointed out in another thread, to test the aperture functions on a Canon FD lens without a Canon FD body you need three hands, a strong paperclip, and the knowledge where to stick it. Your lens is probably fine.
Take a look at this - if you've unlocked the breech ring you're probably at the stage around 1:10 in the video:
http://www.youtube.com/watch?v=N0JczOo9OHg
It's qute likely not broken...
I am the original poster about the need for three hands. Manually functioning the aperture on a Canon FD body is virtually impossible. There's a tiny pin in the very back of the lens inside the shelter of the breech ring. You have to depress that, and work the two levers on the back to see any aperture movement. In addition, you should have the aperture selector set to the middle of the aperture range.
Mounting it to a Canon Body and then opening the back of the camera and opening the shutter on bulb, and then turning the aperture ring will be the best test. Canon changed the Breechlock mount for the FL and FD lenses a couple of times. The last Canon FD lenses also did not have the big round lock ring, but rather locked into the camera by turning the whole lens.
This tricky interlock situation and the evolution of same, is vastly unlike other lens mount systems (the reason for the massive mount change on the EOS)
In fact, those people using the FD lenses as legacy manual focus lenses on digital camera's need to be very cautious to get an adaptor that engages this interlock system .
I sell a lot of Canon FD lenses, and this is always an issue. People contact me all the time because they can't fiddle around on the back of the lens with their pudgy fingers and see the aperture blades move. When they do as I say and mount it to a Canon body...works fine.
In many years of selling camera gear, I have only seen one Canon FD lens with an aperture problem. And on that lens you could not move either of the levers on the back. Jammed solid.
PS... Albinar... pretty sketchy.. no quality there.
I've read that you can get a "Macro Hood" for a reverse mounted lens, which is basically a rear cap with the center cut out. So If you've got some spare caps, and a hole saw, you're in business. Once in place, you can work the aperture ring in normal. I've got the same lens in a Minolta mount, and though it's not the best lens in the bag, I still like the macro feature.
PF
