LCT
ex-newbie
Sean Reid said:...That's a removeable cover you say?...
Yes but the port looks disabled at first glance.
At least it does not communicate with my Macs.
Best,
LCT
LCT said:Yes but the port looks disabled at first glance.
Best,
LCT
PaulN said:...I'm curious to know what it has listed in the USB subsection... Also, while the camera is attached to the computer, check the menu on the back of the camera. Did any new options appear?...
fgianni said:Mine had the same problem a couple of months ago, but I managed to fix it the following way:
1) did a partial calibration
2) switheed the camera off
3)repeat 1 and 2 untill fully calibrated.
I think it took me 3 or 4 cycles, but it has been fine since.
PaulN said:It seemed futile for the first 3 tries. On the fourth, I noticed that the needle didn't start off at the 8 o'clock position, it was closer to 9 o'clock. By the 6th time, it was perfectly aligned. Keep trying, it _will_ work eventually.
Paul
fgianni said:On the first tries it seems futile only if you look at the starting position, if you look at the ending position of the needle, you should see an improvement straight from the first try, at least that is what I saw with mine.
Cheers
Plasmat said:As previously discussed, the usb port will do nothing without the drivers and the proper software. The port won't even show up.
You need the Japanese-only diagnostic software and driver package, not available outside of Seiko-Epson Japan.
I like them, and think they're more intuitive to read than an alphanumeric LCD. The image counter is only vague for 100+ images, when exactness is immaterial.ZorkiKat said:I wonder why Epson decided to use a dial gauge instead of a tiny LCD screen?
RichC said:I like them, and think they're more intuitive to read than an alphanumeric LCD. The image counter is only vague for 100+ images, when exactness is immaterial.
Also, remember that Epson is actually part of Seiko, who've masses of expertise when it comes to analogue displays. No one complains about quartz-driven analogue watches being unreliable and preferring LCD ones! Of course, having mechanical components, they will eventually suffer wear - but if go down that route, why not go the whole hog and have solid-state camera: the same can be said for mechanical shutters, shutter speed dials, aperture rings, etc.? Personally, I like the tactility of the R-D1 - part of my enjoyment of photography comes from the tool I use.
Yes, a few R-D1s suffer from the calibration problem, but there is a fix. Presumably, if Epson were more on the ball with their customer service, it wouldn't have been left to the users to work this out!
There have been rumours about expense, but I don't believe them: the dials presumably use the same cheap and well-proven technology as in Seiko watches. Yes, more costly than an LCD, but I doubt it's as significant as some people think.
You couldn’t see that little clock thing with the LCD folded-away, and anyway it would spoil that cool pre-war lookfgianni said:I definitely wouldn't swap the analogue dials in my R-D1 for an LCD, they do their job much better.
