Angle finder tech info
macmx
8:47 PM
Does anyone have the figures for the diagonal and horizontal view of the Voigtlander Angle finder, and its attachments?
Also, is the frame out of the viewfinder square?
I am asking since this is for use with my Hasselblad SWC which has 72 degrees horizontal and 90 diagonal.
Any help is much appreciated. Thanks.
Wow - I know I'm not the sharpest knife in the drawer, but this is the first time I didn't even understand the question!
I think he's trying to figure out if he can use the CV Angle Finder on his Hasselblad SWC.
To answer the question, the way I understand the AF is that it is intended to be used only with the 12mm, 21mm, and 25mm, and not by itself. Therefore, it would make sense that the angle of view (as well as the shape view) is intended to be used with 12mm, 21mm, and 25mm lenses (in 35mm terms).
