ferider
How do you calculate nominal focal length? I'd like to try with my Zuiko glass!
This is what I did, BT:
I measured the length of the lens at various focus scale settings. I used the infinity measurement to offset the other measurements. Then I predicted focus error using
1/Id + 1/Od = 1/f
where Id is the image distance, Od the object distance (lens focus scale), and f the focal length.
I am interested in getting more details of how you attached the tube Roland. If it is a part that you can easily make I would love to get one from you if you decide to make them available even if they will need slight adjustment by the end user. I have one of those Pentax lenses as well and I always thought it would be ideal to convert it being as small as it is.
Patrick, I debated if I should solder or glue. In the end I used an Epoxy based glue after roughing up the surfaces. Feels very strong. If you don't mind doing the end adjustment (filing down the last mm or so of the cam to fit to your camera), I'd be willing to do another one - still have some pipe. But I would need your lens and adapter for a couple of weeks. And for the lens, this is not reversible, the adapter remains untouched. Still have some brass pipe. Send me a PM if you really want to do this.
Roland.
