Another GX Meter Issue
9:04 AM
Hello all,
Got an Electro 35 GX on ebay a week ago and it appears to be metering incorrectly, indicating that a lot of shots are underexposed which, when compared to the GSN I also have, seem to have plenty of light (full daylight inside). Where the GX says a given shot is underexposed at f/2, the gsn gives no yellow light until f/8. Set, of course, at the same film speed (400).
I am assuming this is a problem, but I'm new to all this. I can still return the camera to the ebay seller.
Thoughts?
Much obliged.
david
Perhaps I've muddled the question, which essentially is: should a gsn and a gx meter about the same for the same shot, given identical film speed, correct battery charge, identical composition?
As it is, the gx gives me a low exposure light significantly earlier than the gsn does, under the same light conditions, and both wide open at f/1.7. So I can shoot with less light with the gsn. Does that seem unusual?
Thank you kindly, Col. Sebastian! Just what I needed. I believe the meter is actually alright, after going through the tests you recommend. I also ran a roll of film through it and it came out alright.
A final question, though: if the meter was off, how would it show it in the developed film?
Thanks again so much.
David --
Look at your negatives, not the prints or scans. Judge them for proper density.
A good negative will be rich with a broad range of densities. If it's very dark everywhere, that's over exposure. If it's "thin" that's under exposure. (Note that color negatives have a strong orange cast overall; that's normal.)
If you are not familiar, go to images.google.com and search on "c-41 negative" for examples.
