shadowfox
Darkroom printing lives
So how did I happen to own this somewhat obscure camera? It was the 14mm semi-fisheye lens that someone was selling for about $75 new as I recall. Way back yonder there weren't many 14mm lenses available and none for $75 (a deal I couldn't refuse). Quite a bit later I got a body and used metal tape to change it to the panorama format. Amazingly little distortion when you just use the strip across the center of the negative. I have compared this lens to a 16mm semi-fisheye and it has a significantly wider field of view! I also have the 28mm, 35mm, 50mm, and 135mm lenses. In the past you could get these lenses for under $50 each If you were patient. Anyway, I'm glad to see someone else appreciates this camera.
That is just incredible.
I am not a fan of fisheye at all, but if I can get an extra-wide rectangular image out of it, that's cool.
I found one of these at a thrift store with a 50mm macro lens, 35mm and a standard 50mm.. The camera is quite nice. Shutter controls like an OM camera. Unfortunately the film advance was wonky and I couldn't figure out how to fix it, so I sold the lenses and body on eBay.
I wouldn't mind the 50mm macro. But when the 3D printed M42 adapter arrived, I can test it with my Industar 61L/Z which is macro-ish.
Beautiful indeed. It has a model number that they'd surely like here in North Carolina. 😀 Will, upon seeing the first pic in the original post, I was going to ask what the orange thing does -- until I read on. But a clarification: is the orange square both the button to press, and the light that lights? Weird if so. Interesting camera, but I tend to shy away from these orphan mounts with limited lens availability.
--Dave
Dave, that explains the sudden urge to buy when I see a Canon TX (haha...)
The orange square on the top will light up when the orange button is pressed indicating battery status.
Mamiya, having such a good line of MF cameras, never seemed to market their 35mm cameras well. They did have some perfectly acceptable 35mm cameras. I wasn't aware of the OP's camera. It looks like a nice user. Shame they didn't expand on it. Looking forward to seeing how you like it as you continue to use it.
Yes, I have a Fuji Superia 200 in it right now. My standard test roll so I can see orange streaks if there are any light leaks.
So far I'm happy with the handling, it is surprisingly familiar due to the shutter speed around the lens mount.
I had a wonderful NC1000 with a range of 4 lenses and loved it. My sole complaint was the fact that the little button on the top would release the arm and simultaneously turn on the meter. Many times I found that the button had been accidentally pressed in my bag and the meter was dead. After replacing the batteries several times, I retired the little camera and eventually gave it all to a friend who was interested in learning about photography. Except for this one flaw, it was a fine little camera with an excellent selection of lenses and all very inexpensive.... except for the batteries.
Actually it's the reverse.
The round button on top of the film advance lever will pop-up when the meter is on (the lever is at about 30 degrees from the body). If you push it down, it will turn *off* the meter and make the lever flush to the body.
It reminds me of Konica T4 in this regard.
