Any Makin 67/670 owners? Need HELP!
Jaehoppa, everything is fine. It is okay to dry fire, nothing different than when film is loaded. It is just a shutter.
The double stroke reduces the stress on the film advance gearing. This was done to improve the long term film advance reliability over the 67.
You can make the 670 fire without film in it by holding the right roller as you advance. But it isn't set up to fire without film, and unless you need to adjust the rangefinder (have shutter open), I wouldn't.
Everything is fine.
thanks!! i feel much better. I think I got all my questions answered here and thru some makina users in a korean forum.
Thanks for taking effort to clear things up for me.
Thank you all!! I'm gonna go enjoy my new camera! 🙂
You're going to love this camera, it takes beautiful images.
How much did you pay for it?
i bought the makina 670 in very clean condition for $1600 flat on ebay. Is this a good price for it? seems like it is, compared to the ridiculous buy it now prices.
the 670 is worth a little more than the 67 right?
670s tend to go for a bit more than 67s, I would guess it's because 670s are a few years younger.
And yes, $1600 is a good price for a 670.
Have fun with it! I'll never let mine go.
Just FYI, the 670 is a better camera than the 67. They seemed to work out some of the kinks, especially the weak film advance, of the 67 and put upgrades in the 670. Also, the 670 has a nice ribbed surface (for her pleasure🙂) as does the W67. So, I'm thinking that the W67 came out after the 67 and nearly to the same time as the 670. I sold my 670 and only have the W67 left along with the Bronica RF.
One thing you can do for sure is that after you take a picture, advance the film slowly and smoothly. Even though the 670 has improved gears, it still is a weak point.
You paid a fair price.
Enjoy,
Joel
YOU MUST REMEMBER TO DO THIS; Before you collapse the lens panel,remember to focuson infinity. You do this by turning the focusing ring that surrounds the shutter release towards the centre of the camera.
If you hold the camera flat in the palm of your left hand,press the lens panel release button with the index finger of your left hand,while holding the front of the lens panel with the thumb and forefinger of your right hand and as the lens panel lock releases,ease the lens panel towards the body until it stops.
If you do these things carefully every time you use the camera you will avoid some of the major problems that affect this camera.
When you have developed your first fill,if there is any uneveness of spacing between the negatives let me know and I will talk you through how to retension the spring around the take up spool to avoid the spacing issue.
Good luck and welcome to the" Makina madness club"
Thanks for the tip. I've actually read about this before and trying my best to be careful each time I collapse the lens. I also know that I shouldn't turn the focusing dial when the lens is collapsed but what damage can it cause? I'm sure I've turned it a bit a couple times without know but I should be ok right?
Also thanks for offering to help with the spacing issue. I will let you know when I develop my first set of rolls.
Thanks again!
Enjoy,
Joel
Glad I chose the 670 over 67 at the same price. Even though I like the look of the 67 better I had to go with the 670 due to the improvements.
I will make sure to turn the film advance very carefully.
Thanks again!
at the same price the 670 over the 67 is a no brainer, the 670 is probalby the most advanced makina made, as they improved the gears and takes 220 film too, but also the changed the design a little not to everyones taste.
I went for the W67 because I wanted the wider lens, and the previous owner had it overhauled with completely new gears at plaubel, so it should be good for some years to come, the W67 is usually more expensive than both, but probably more due to the rarity than anything else.
All Makinas are absolutely great imo, won't sell mine
Hi jaehoppa,
During shooting the film unrolls from the left and onto the once-empty reel on the right. When finished, you'll take the completed roll out on the right. Before putting the new reel in, you'll move the empty reel on the left to the right, and the new reel goes in on the left.
Noobs have more fun.
Let us know how things go with the Plaubel, and keep asking questions as they come up.
http://aspect-ratios.net/rangefinder-cameras/wp-content/uploads/2011/08/PLAUBEL-Makina-W67_02.jpg
I have one more question. If you look at the picture in the link, the long plastic piece is on the left side but isn't it supposed to be on the right and a film is supposed to be on the left? am i missing something? all the pictures that i found of the makina has the plastic piece on the left..
: ) .......To remove the spool there are 2 buttons on the bottom of the camera that need pushing to remove the spool and insert the film ... Remember to lock them after you load the film .....
