Any rangefinder rival modern lens?
M
marlinspike
Guest
Is there any rangefinder, other than Leica, that can rival modern Canon L lenses? Why "other than Leica"? Because Leica=$$$$, no other reason than that.
Richard
Hummm... well there are a few rangefinders that can take M mount lenses, is that what you mean ?
Richard
well, that's comparing apples and oranges. By design, an SLR lense is very different from a rangefinder lense (think retrofocus for example).
In terms of pure optical capacity, look at tests that measure resolution AND contrast across the field, corner and center of the film, at different apertures and different distance of focus. Check flare resistance, astigmatism, decenterism, colour rendition,etc.
Only then can you provide a fair assessment of a lense.
Then compare against the price.
Today, Voigtlander achieves pure optical performances that are quite astonishing.
I'm talking descent contrast beyond the 100lp/mm limit.
Quite frankly beyond this limit, only a tripod can do justice to these lenses.
Hand shooting with a Canon L or a Voigtlander or Leica and talking high resolution
is irrelevant.
My 2 best lenses are the Pentax Limited 77mm f1.8, and the Voigtlander Heliar 50mm F3.5. Rolls after rolls, amongst the 13 lenses I own, they prove to deliver the most consistent quality of imagery.
A renowned photographer here in Perth cut open some Canon lenses (yes, L lenses too) to show them the insides. Shocking, not even all surfaces were painted black. Canon L lenses arnt as well made as Voigtlander lenses.
So if your buying new, unless its russian, its better than Canon L.. Canon L is a marketing thrust.
Daniel.
Richard
Just look on the Contax G lenses. Maybe it isn't "100% RF system" but lenses are just great and much cheaper than Canon L.
best regards
No no, I don't like Contax G. I suppose I should be more specific in my request
I don't want something that uses Leica lenses because Leica lenses are so expensive
By "rival" I should probably just say "rival in sharpness" I don't think there are any rangefinder lenses that will fall behind Canon L's (at least no L zooms) in contrast or saturation. I'm not too concerned with vignetting or distortion either because all I want on a RF is a 50mm lens...MAYBE (and a weak maybe) a 35mm too.
I don't want something like a Contax G, I want something that is old timey (doesn't actually have to be old...if a Leica M7 weren't so expensive, it would fit what I want well). Must take no batteries (if you remember when I bought my first RF, I wanted no batteries and a lightmeter, but the more I use this Kiev, the better I'm getting at just eyeballing the exposure, so I'm dropping the light meter requirement). Also it has to have an internal rangefinder, no external rangefinders for me.
What Canon L isn't painted black on the inside? And I don't see how hand shooting and talking L is irrelevant as long as the shutter speeds are high enough and you don't have the shakes. And BTW, Canon L, while the L name is marketing, the lenses are a lot more than "marketing thrust"
Richard
How about the Hexar RF ? The hexanon 50mm is supposed to be one of the best 50mm rangefinder lenses ever, and the system isnt half as expensive as leica 🙂
Not sure if I'm responding to the question, but I have to say that my new (to me) RF lenses are at least as sharp as any of my Canon L lenses. No doubt. My RF kit includes older Leica and new CV glass.
But sharpness misses a large part of the point. I believe there are other qualities that matter more, and you can find these qualities in RF glass more than in SLR glass. There is just so much more range and variety in the "look" provided by RF glass. With the exception of the Canon 85/1.2 and the 200/1.8, there aren't any classic lenses in the EF line, IMHO. But RF classics ... there are so many, many to play with. And at such reasonable prices - just think of the Canon LTMs, for example.
I'm certain I deserve to get flamed here, esp given my relative inexperience. It just seems to me that one of the attractions of RFs is the variety of available glass.
Right on, Mike! That a camera body accepts Leica lenses doesn't mean you must put Leica lenses on it; there are a number of other attractive choices if you need to keep down the costs.
