css9450
I always used my FM2s with their motor drives. They handle great and I don't mind the sound. I also have an FA with its dedicated drive MD-15, and its louder than the MD-12s.
... and the damn things would jam every fifth roll or so for no reason
Jammed, as in physically wouldn't fire, or was it electrical? I noticed two things with my two MD12s: One, it was necessary to clean the battery contacts every time I changed the batteries, otherwise corrosion (or something) would cause an intermittant loss of power. Cleaning the contacts cured that problem. Secondly, if I'd removed the MD12 from the camera and fired it for some reason, it was likely to be "out of sync" with the camera and required careful realignment of the drive prongs on the bottom of the camera. Advancing the film partway until the prongs could be seen to match those on the MD12 allowed me to re-attach it to the camera with no problem.
...i'm trying to train myself to make more exposures, even if they are only minutely different from each other...
Planning to go digital? 😉
Chris
You'd put a new roll in and it would be frozen until I removed the drive and reattached it. This was with it securely fastened to the camera for the rolls prior.
