Anyone here using Russian Wides and Ultra Wides.
Rob, J12 can have QC issues, trust me on that. I had to re-collimate my black Kiev-mount one, it was so off that apertures wider than f/8 were unusable.
There are a bunch of Mir series SLR lenses in 20 to 28mm focal lengths not mentioned here. They were made in K, M42, Nikon and Kiev-15 mounts.
Mir-1 is also an SLR lens. An early retrofocal design with compromises to image quality. Mir-1v (Мир-1В) type reputed to be worse than older, KMZ-made chrome Mir-1.
Jupiter-12 is a faithful copy of pre-war Zeiss Biogon. Softish at 2.8, rapidly improves from f/4 and on. I think the earlier (esp. KMZ-made) samples are better than black Lytkarino-made ones.
Russar-MR2 is the only consumer lens of Russar type ever made. Russar type was designed for aerial photography, the advantages are nearly non-existent distortion and 0% geometric vignetting. Yes, 0% - that was the patented part of it. Super-Angulon, for instance, had it at 44%. Ludwig Bertele's postwar 35 and 21 Biogons are derivations of Russar.
Orion-15 is an adaptation of Zeiss Topogon, also an aerial lens design. This design requires extremely precise assembly, hence the aperture on consumer Soviet copy was limited to f/6.
I can assure you that the J-12 fits Leica III series bodies. It fits the Canon III series and almost certainly the Canon II series. I've heard several commentators indicate it fits the Leica M2 and M3. It does not fit the Bessa R or the Canon L1, which probably also rules out any Canon body after the bottom loaders (i.e rules out all the Canon's with rapid advance levers or triggers).
