Now I will follow up my last post with saying that my current usage of Diafine is slightly different than that:
First, I use it as a 1 shot developer, rather than a reusable developer. In doing that, I dilute each solution 50/50 with water immediately prior to use (see below).
Since I am dumping it after each use, I try to develop as many roll or sheets as possible at 1 time. I use the tall Jobo developing tanks and a roller base to continuously agitate throughout the development. But it allows me to develop quite a bit of film in only 800ml of 50/50 solution - - so dumping it out isn't that bad, economically.
My development sequence is as follows - - all in the Jobo tank and Steps 2-8 with continuous agitation:
- Load all the film in the Jobo tank - - all film gets treated the same, sheet or roll, no variation by brand or speed.
- Pre-soak the film 4 minutes in 800ml of water with 7 drops of Photoflo in it. Dump.
- Process 4 minutes in diluted Solution A (400 ml Solution A + 400 ml water). Dump.
- Process 4 minutes in diluted Solution B (400 ml Solution B + 400 ml water). Dump.
- Wash 30 seconds in 1000 ml water.
- Process 4 minutes in Rapid Fixer. Keep or dump - - whichever you want).
- Wash 2 minutes in running water.
- Process 1.5 minutes in 800 ml Hypo Clearing agent, mixed according to the directions. Dump.
- Wash 6 minutes in running water.
- Dunk each reel in Photoflo solution for 30 seconds then in/out dip in distilled water.
- Hang to dry - - do not squeegee.
Following this process, I shoot all my B&W film at box speed - - no "speed improvement" that you usually get from Diafine. The real benefit, to me, of this process is that it flattens the contrast a bit and yields much more manageable images down here in the bright TX sun... so everything is not so high contrast that you can't do anything with it.
YMMV...
