anyone uses a goggled Summicron 35/F2 ver. 1 on Konica Hexar RF?
roundg
1:27 AM
any issue? as RF has the same physical baseline as Leica M, I suppose the goggled lens should be able to focus correctly on RF.
Thanks,
I have such a lens and I will try to use it on a Hexar RF and M6. It should work fine. The goggles will widen the view, but the VF frames should still be fine. Am I correct on this one?
I have a Summicron 35f2.0 with goggles and I am wondering if I can use it with my M6?
Joe
Yes, you can. It was designed for the M3, since that only had 50 as the widest frame, but will work fine with the later M's too, since the windows are in the same positions. I use a goggled summaron 35mm f/3.5 w/ both my M3 and M6TTL.
-Brian
Raid- it'll pull up what are usually the 50mm framelines, but with the reduced magnification these will be correct for the 35mm.
-Brian
The lens just arrived. Feels good and focus good on RF as compared with on my other M bodies. Will run a testing roll through it.
attachment.php
