Anyway to make vertical and horizontal RF match easily? FED 2
Adjust the lateral RF first using the screw behind the middle one (under the E in Fed). The take the outer bezel off the RF window and adjust the vertical alignment.
Kim
Kim
Kim,
Wrong way around - adjusting the vertical will also affect horizontal so it needs to be done first...
The silver round outer bezel just screws off. Then you need to turn the inner ring with 2 spanner notches for vertical alignment.
Jason.
2314389541
thanks jason
see image
http://www.flickr.com/photos/24432469@N04/2314389541/
tomaas
Tomass,
In your picture you have unscrewed the entire assembly. You need to get the silver ring off and screw the rest back on the camera.
Jason.
tomaas said:
jason,
i can't do it!
what can i do to get only the silver ring?
tomaas
Screw the whole thing back in, fairly tight. Then heat the ring with a domestic iron or by moving a pencil-flame blowtorch around it for a couple of seconds (be careful after of course!). You could also try soaking the threaded part in a penetrating oil for a few days: apply a tiny amount where the bezel meets the prism housing, with it removed as per the photo.
