aperture ring hard to move on 50mm serenar
cjm
2:21 AM
San Diego
I just got Canon 50mm f1.8 Serenar described as "ugly" and it is indeed ugly. The aperture ring is very hard to move. Two hands are necessary to move it. Is there a quick and easy way to fix this or just loosen it up a little? I'm not going to pay for a CLA because I got this lens for about the price of a Jupiter 8 just to hold me over for a month or two until I can afford a better lens.
Any suggestions?
-Chris
Do be too rough with it - you may distort or elongate the locating holes for the pivot pins for the blades - causing all sorts of nasty problems.
The ring inside the RF cam unscrews with a spanner wrench, then the entire optical block can be removed. Don't lose the spacer ring! The stiffness may be just grease gone to glue on the outside of the block (detent mechanism), or you may have to take it apart. Make scribe marks showing how tight the front and back lens cells are screwed into the iris cell if you remove them.
Realize that putting aperture blades back together can be VERY fiddly.
It may be tight because it's bent. That would be sad.
The friction point is likely to be rather far from where oil can get from the outside.
I just popped mine out of the mount to work out the details. You don't really need a spanner wrench, a stainless steel desk ruler worked for me.
Once you have the optical block out, you'll see all the aperture mechanism. There's a black lever that attaches the outer ring to a pin coming out of the inner ring that operates the iris. First make scribe marks to note the exact location of that lever, it has oblong holes that calibrate the exact aperture! Remove that lever, see that the inner ring moves with no binding when you slide the pin side to side. If it doesn't, you need to do a complete tear down, clean that ring, and reassemble. (Not fun.)
If the inner ring moves freely, you just proceed to remove the bronze spring and detent ball. (Don't loose the ball, probably metric, a pain to replace.) Lift off the aperture ring, clean mating surfaces thoroughly, apply smallest amount of light oil, and reassemble. You'll need to fine tune the location of the bronze spring to get the aperture marks to line up with the mark.
attachment.php
