42 explains life, the universe, everything.
It is THE answer.
Phil
...what focal length, in what format, and based on what circle of confusion? What print size is it expecting?
The point I and a few others are making is that asking for "the appropriate settings for a 28mm lens" is like asking for the length of a piece of string. What type of string? What do you need it for? Even shoelaces come in different lengths.It is for 107.8mm lens for a 6' x 8' print. What did you expect? Did you expect a chart that pertains for the discussion? Oh, my God, man, you are so out of step. Circle of confusion?? This thread, Bucko.
CoC is for engineers, not photographers.I don't have the original attribution, but I read somewhere that a Circle of Confusion is a group of photographers sitting around discussing Depth of Field.
Genuine question, though: with CoC being tied to print size and the expectations of the size of a standard print changing from the 1920s to the modern day, surely that'd mean the "depth of field" standards should change at the same time - in other words, the engineers calculating the depth of field scales on lenses would/could/arguably should have altered them slightly to reflect the larger prints that became popular later on.CoC is for engineers, not photographers.
I don’t know any engineers who do depth of field scale design, but probably. Certainly lenses that looked allright, and depth-of-field settings that looked ‘sharp enough’ for a folding medium format camera whose output would mostly have been contact prints would not cut it on 35mm, let alone a digital sensor. But the scales are notably different on those lenses and cameras.Genuine question, though: with CoC being tied to print size and the expectations of the size of a standard print changing from the 1920s to the modern day, surely that'd mean the "depth of field" standards should change at the same time - in other words, the engineers calculating the depth of field scales on lenses would/could/arguably should have altered them slightly to reflect the larger prints that became popular later on.
That might explain why the Canon 28mm Serenar's depth of field is slightly more "permissive" than the VC 28mm from the 2000s. Maybe.
To paraphrase Terry Pratchett - "Give a man a the time and he will know the time for now. Tell a man how to make a watch and he will know the time for the rest of his life."It is interesting to see folks post numbers for 28mm depth of field. I posted a link to several 28mm depth of field charts in my post, the second IIRC, which have been pretty much ignored in preference for discussion of what it is and how it works. I was misguided in thinking that the request for DoF info was cut and dry. LOL
It seems the OP asked what time it is and has been told how to make a watch.
The usual 'reference print' size of 8x10 inches works fine even if the average size of prints has increased over the decades since DoF was defined. The reason it was chosen as the DoF reference is that 8x10 inch is a 'large book' size and is about the largest size print that can be comfortably viewed in its entirety held in your hands and seen as sharp with normal 20/20 vision (whether uncorrected or corrected). Larger size prints are usually viewed from a somewhat greater distance, even today, and since perceptual sharpness is dependent upon the acuity of the human eye, at viewing distances greater than 14 to 20 inches the acceptably sharp CoC tends to be larger.Genuine question, though: with CoC being tied to print size and the expectations of the size of a standard print changing from the 1920s to the modern day, surely that'd mean the "depth of field" standards should change at the same time - in other words, the engineers calculating the depth of field scales on lenses would/could/arguably should have altered them slightly to reflect the larger prints that became popular later on.
Sorry Sir, I just thought communicating an idea was more important than pedantry, sometimes you have to decide when to say something even if you know it, and when not. I will however continue to adhere to common understandings in future as everything else unless entirely relevent is just 'showing off', don't you think?There is no such thing as a point or place of focus; only blur circle.
I’m not a sir, and I’m not showing off. Sorry.Sorry Sir, I just thought communicating an idea was more important than pedantry, sometimes you have to decide when to say something even if you know it, and when not. I will however continue to adhere to common understandings in future as everything else unless entirely relevent is just 'showing off', don't you think?
