Arista 400 Pro--expired eleven years ago
jwc57
11:09 PM
I came across a can of bulk film, Arista 400 Professional film, marked "Made in England", with an expiration date of March 2000. I loaded it in the bulk loader and I was going to run a couple of rolls to see if it was anywhere near being Okay. (It is a can of film someone gave me and I forgot about it. It was in the back of the camera cabinet instead of the freezer where I thought it was, so it was stored at a constant temperature in the house, but wasn't "preserved".)
After reading some threads and posts on here, I thought I would ask a couple of questions....
What, if any, allowances should I make during exposure? For example, should I dial it in at ISO 800 instead of 400 to accommodate any loss of sensitivity?
How should I process it and what chemicals would you recommend? (The only fresh developer I have right now is Ilfosol 3 and D76---but, I'm wondering if something like Diafine would be better? I also have two packages of Dektol).
My thinking behind this is that if the a roll doesn't turn out, I should eliminate my errors instead of just writing off the film as "gone".
That would be Ilford film (HP5?).
It's probably still very good but it's likely lost some speed and may have a bit of base fog. Try shooting it at 200.
Ilfosol 3 and D-76 should both work well. If it were me I would use a lower dilution (Ilfosol-3 at 1+9, D-76 at 1+1) and look for the quicker development time to keep base fog at a minimum.
Thanks.
I went ahead and ran twelve frames...half at 400 and the other half at 800, just to see what would happen. No difference really between the two different speeds. I developed it with Ilfosol 3 at 1+9 and 6:30. It turned out contrasty and very grainy, but no fog.
I'm wondering if Xtol would give me better results.
I shot some 120 HP5 and used the same development as above. That seems to turn out really well. Of course, it wasn't 11 years old.
