Tom A
RFF Sponsor
I find the HC 110 a bit "rough" with 35mm TriX. However it works very well with Neopan 400 and Tmax 2-400. I suspect that it needs an inherently finer grain film to work well. With TriX it has an edge, similar to Rodinal/Beutler.
The Xtol works well, but for some reason it is a developer that I use very little. I have tried it with the Xtol/Rodinal combination and it is OK. Quite smooth and with some edge to it. I do have several packages of the 5 liter Xtol and I should really try it some more.
The D76 just works, but then it could be 40 years of using it that makes it easy to handle. I can adjust exposures "on the fly" for it and if you limit the size of prints to 16x20 - it looks pretty good. Master printers can pull of magic with it - I have seen 24x36 inch prints that look spectacular - but that is more based on the skill of the printer than the developer/film combination.
The D76 grain is softer than either HC110 or Xtol - but if you print it big and remember to use the "rule of thumb" for viewing big prints. Use the diagonal dimension as the viewing distance - and it looks good.
It is just that combination, TriX and D76 - it was really made for each other.
