R
ruben
Guest
pangkievrange said:Since lenses for kiev are so small, I can carry a full set of lenses in a bag in bakelite cases that have soft foam wraps for the case and cap to take up the space inside as cushion. Thus, the lenses do not bounce inside the case.
pangkievrange
I followed this path with some additions. When I take all Kiev lenses I use a quite small belt pouch, TAKING A GREAT ADVANTAVE OF THE BAKETLITE cases. The lenses are organized in the following way: on the left and right side of the belt pouch I have the J-11 and J-9 without any caps, inside the bakelites, with their bakelite tops UNSCREWED.
The J-8 and and J-12 go in the middle, one on top of the other. But this deserves a little detaliling. For the defending of each lens REAR I have reformed their respecive bakelite cases so they fit by pressure. For the J-12 I use inside the bakelite the J-12 plastic cap, fixed to the bakelite by padding the in-between space. Therefore, when I take the J-12 from my camera, I screw the whole REAR backelite compound
The same with the J-8, just the compound is easier to assemble.
Now regarding the tops of the J-8 and J-12: I said I don't use the bakelite tops at all for these lenses. The J-8 goes allways with a 49 metal hood via step up ring (for whys and hows follow the thread regarding 40,5 filters).
The J-8 and J-12 in my belt pouch FACE each other, one on top of the other, the 49 metal hood defending the J-12 top lens.
Thise whole package is extremely compact, and extremely fast to use for changing Kiev lenses fast and simple.
A further step possible to take, that I haven't is to pad the external side of the bakelites, either with leather or any similar thin material. I haven't as after cleaning the bakelites with Brasso, they shine more than when left the factory and my aesthetical sense here contradicts my general orientation regarding equipment safety.
Ruben
