The major difference between similar-sized batteries is the drain rate design. Some are designed for higher rates of discharge and others for slower or steadier rates.
Using a battery for one discharge rate in another device or application probably won't be harmful, but you may not get optimum life out of that battery.
Silver oxide batteries provide good life/usage as Keith noted above. They tend to hold a very steady charge then fall off the cliff going from OK to dead very quickly. The MS76/SR44 (different mfr designation for the same battery, more or less), work well in photo applications.
You may also substitute a 1/3N lithium battery in a normal 2-battery setup without any difficulty, usually. The lithium battery has the major advantage of not leaking nor swelling like the MS76 and SR44's do at the end of their life. It also tends to have better low temperature performance, longer shelf life - up to 10 years, and may be a bit cheaper than the 2 battery setup.
