Turtle
Maybe this addition to the density/contrast issue will help:
places within the negative where you can see no density i.e. the same as the film margins outside the negative frame area which has not been exposed to light, will not grow in density in real terms no matter how long you develop as there is no image density here to develop. This will therefore remain relatively clear.
Al films differ in terms of how clear the the film base is outside the image area. Some are very clear and some quite dark and almost frosted looking. Generally the slower the film the more crystal clear the film base. Faster films, like HP5, TriX and Delta 3200 tend to have more of a density here. Thats normal.
- The longer you develop, the more silver is developed in the frame in overall terms i.e. more dense.
- The longer your develop, the more the highlights in the print (the dark bits in the negative) will keep growing in density.
- With development time, the shadow areas (the thinner areas on he negative where there is only a little silver developing) will also increase in density, but only very slowly and a little.
- The above two comments are why the longer you develop, the more contrast you get. This is because the dense/highlight areas keep building quite quickly and the thin/shadow areas build only a little bit. The 'scale' of the negative is therefore stretched with time.
