lawnpotter
Would you do it? Would I end up with a lot of out of focused shots? Does any one have any examples using this combination? Thanks
I didn't use a 35 on my Bessa-L when I had it, but I have done quite a few shots with an Olympus XA2 - 35mm lens, no focusing aids - and most of them were sharp. If you can keep the aperture reasonably small and get good depth of field, you should do OK (you get something like 2.5m to infinity at f/8).Would you do it? Would I end up with a lot of out of focused shots? Does any one have any examples using this combination? Thanks
True, but here you've got to keep in mind that at the time when scale focused 50s were commonplace, the most common print size was 6x9 cm, ca 2.5x3.5 inch. At that enlargement size, focus errors didn't really show up.Roger Hicks said:Bear in mind that the original Leica had a 50mm lens and was scale-focused, and there were plenty more 50mm scale-focus cameras after that..
Dear Peter,pvdhaar said:True, but here you've got to keep in mind that at the time when scale focused 50s were commonplace, the most common print size was 6x9 cm, ca 2.5x3.5 inch. At that enlargement size, focus errors didn't really show up.
It does require much more care if you want acceptable sharpness at 10x15 cm, 4x6 inch, from a guess-focused 50.
Of course, every one has different distance guesstimation skills. Mine top out at 35mm for 10x15 prints.
