bessa R lever frameline selection
atelier7
9:54 PM
When selecting the different framelines on the Bessa R, do you find that the lever clicks nicely for the 35 and 50mm but there is no 'click' when selecting the 75mm framelines?
Mine clicks pretty much the same for every selection. Unless you suspect the 75 framelines are incorrectly positioned due to a malfunction in the selection lever, or you find that they won't stay at 75, it's probably nothing to worry about.
Mine clicks solidly into place at all three settings. However, I can sometimes bump the lever and cause it to move between the various settings, with the resulting slanted framelines. All three settings, when properly set, are level in the viewfinder.
Kevin
