paxship
If the R2a shutter has a range from 8 to 1/2000 seconds, and the meter has a range of EV 1 to EV 19, under what conditions (EV and ISO) would it select 8 seconds? As you know, an R (and probably any Bessa's) meter will "freeze" if you set the shutter speed at anything more than 1/(ISO/100)... that is with ISO 400, the meter work if the shutter is set for 1/4, but will "freeze" at the minus sign if you set the shutter to 1/2.
