Bessa R3 lenses
sanardo22
7:57 AM
I undrstand that the Bessa R3 can be used with Minolta, Canon and other lenses that are compatable with with the camera's mounting configuration. Are these lenes coupled to the the camera's rangefinder? ( I have a Mamiya 6x7 and a canonet GIII 17 )
The R3a comes with the M Mount. There is a large selection of modern and older M Mount lenses available from Leica, Voigtlander, Konica, Zeiss and others.
Screw mount (or Leica Thread Mount [LTM for short]) are also frequently used on the M Mount bodies via a LTM to M lens adapter.
Most of these lenses are rangefinder coupled with the exception of a few, examples would include the CV (Cosina Voigtlander) 15/4.5, 21/4 and 25/4. These lenses are scale focused through estimation of distance.
A Terence has stated the CV (Cosina Voigtlander) 15/4.5, 21/4 and 25/4 are scale focus and not RF coupled. As they are very wide angle it's really easy to use the hyperfocal scale. I use the 15 and it's got a huge DOF even at F4.5 (it's much better at F5.6). Don't let the lack of RF couple put you off these lenses. They are all very good.
Huh? I thought the CV 21mm was rangefinder coupled. Has my overtaxed brain finally gone "phut"!!!!!!! 😉
The 21 is coupled. That said, you still can just walk around shooting without focusing becasue the DOF places everything in focus from your nose to forever.
It IS rangefinder coupled, according to the CameraQuest web page:
"The 21/4 is built on the 25/4 lens barrel, with Rangefinder coupling and a convenient focusing lever."​
A 21mm lens at full aperture has a total DOF of "only" about 0.45 meter when focused at 1 meter -- so while guess-focusing probably will work, RF coupling is a useful aid to make sure your guess isn't too wildly off.
