Bessa R3A – first impressions
sockeyed
11:13 AM
Vancouver, BC
My new Bessa R3A arrived from Cameraquest on the weekend (I’ve mated it with a 40/1.4 SC Nokton), and I’ve shot about 100 frames through it. I thought that I’d share my first impressions.
Feel: It’s certainly heavier and more solid-feeling than my Bessa R, not that the R feels bad. The R3A is not as burly as my Canon F-1 or the Leica M’s I’ve felt, but it does feel well made. The material is good to grip and marks less, and the crinkle paint is attractive. The winder feels kind of light on the stroke. The rewind knob is fine.
Shutter: the electronic shutter is quieter than the R’s mechanical one, and fires with a lighter touch. In fact, I fired it accidentally taking light readings a couple of times. A soft-release is almost too much. I like that the shutter locks, unlike on the R.
Finder and Framelines: The 1:1 finder is pretty amazing. With some practice, I think that I’ll be able to manage the both-eyes-open way of shooting. A lot of people complain that the 40mm framelines are hard to see. I agree, and I don’t even have glasses. I pretty well have to press my eyeball against the viewfinder to see all the lines. The framelines also tend not to have a bottom line, which I find a bit annoying. All this said, the viewfinder works wonderfully with 50mm and 75mm lenses. Another small complaint is that the shutter readout can be hard to see unless your eye is in just the right place. This will probably change with practice, though.
AE: It’s great to have aperture priority AE and gives me one less thing to worry about when shooting on the fly. The only complaint here is that the AE lock button does not turn on the meter; you have to press the shutter slightly to get a reading, and then press the AE lock.
The 40/1.4 Nokton: very nicely constructed, good focusing tab, nice tabs on the aperture ring, and cool bayonet-mount hood. Well-designed lens cap, too, which you can take on and off with the hood mounted. Focusing is a bit stiffer than my 35/2.5.
Things I really like: the construction, the bright finder, the M-mount system, and the aesthetics of the camera.
Not so hot about: the hard-to-see 40mm framelines, the shutter speed readout.
Congrats on your new camera. I finally had a chance to handle one (R3a) while on holiday and was very impressed by it.
Bob
Another nice feature is the shutter button lock to avoid accidental releases. I do find the shutton button a little touchy and sometimes when depressing it halfway to get a meter reading, I accidentally let off a frame. I find a mini soft release useful in preventing such occurences.
I call the shutter button lock the on-switch -- I know, blasphamy!
Victor
Everone I know who has used one has taken accidental pictures while trying to take a reading so that must count as a 'known problem' (to quote Microsoft).
I don't hear any difference in the shutters: if there is one, it must surely be tiny.
I agree on the shutter speed readout, especially in bright sun.
Lovely camera, though, isn't it? If only they made it in the same olive drab as the R2...
Roger
Inadvertently taking a picture when trying to meter a scene seems to be a Bessa thing.
It's the same as on my Bessa-T. The difference between pushing the shutter button halfway to meter and all the way to take a picture is ever so small. As I only have the T since a couple of days, I attributed it to having to get used to..
An olive drab model and a grey model model would be very cool.
I scanned my first images from the r3a last night and they turned out very nicely. The exposure seems spot on and the 40/1.4 SC is a very nice lens in terms of sharpness and contrast (although the Bokeh/Sofa is a little bit funky). I'll try and post some samples soon.
received my new R3A
received my new R3A
I just received my replacement R3A from B&H Photo in New York. The first one had a misaligned viewfinder, this new one looks absolutely perfect. Some people are waiting to see how many of these new Bessas are being returned for viewfinder issues and that is a good idea. If you can, try to buy from a local dealer so you will be able to check the alignment on the spot, and not have to deal with the waiting and phone interrogations. BHPhotoVideo is very good to deal with though.
There is another thread going on the bokeh issue, but my experience has been that the bokeh 'cleans up' noticably at 2.8; only wider that that does it have unusual characteristics (a bit harsh, slight doubling). Results otherwise are stunning.
I have a softrelease on mine and it cures the problem. It doesn't fit the R3A perfectly – there is a gap – but it's still great, helps a lot when timing is everything.
An M7. Like comparing a VW to Roll Royce. Both will get you there and when you walk in the door, it won't matter. But oh what a ride.
Or somewhere between an M6 and M7, Or an M6 classic with AE and 1:1 viewfinder. It does not do the DX coding thing. (You also have to remember to change the framelines by hand).
But it is clearly not the same.
My R4A works wonderfully, though. I would probably go for the M model, now, because my reliance on auto-exposure is pretty non-existent.
