rxmd
May contain traces of nut
while adjusting the Bessa R rangefinder a couple of days ago I thought it would probably be easier to do with the top cover removed because I suspect close focus to be slightly off (and because I wanted to fix the screws in place using nail varnish, but I didn't want to pour nail varnish through the holes under the hot shoe).
But how do I get the thing off?
So far I see:
I'm in the dark how to remove the rewind lever and frameline selectors. Can anyone who had his Bessa open enlighten me?
Philipp
So far I see:
- four screws (two holding the front plate with the mount, one at the back, one holding the VF window in place)
- the shutter speed knob: use a two-pronged screwdriver to take out the center screw
- the hot shoe (easy to take off)
- the rewind lever
- the frameline selector
- the fold-out rewind crank - do I have to take this off at all? It should fit through the hole in the top cover.
Philipp
