Bessaflex Discontinued
Having money in my bank account is hazardous. I placed a bid on a Spotmatic SP just because of this thread :p
(I do have two m42 mount lenses and I sold my only m42 to EOS adapter with my fisheye lens so I can't use them, though, and my Canon has something wrong with it so I wanted a backup body)
what a pity. sh*t! all real things are now discontinued. seems i'm stuck with old spotmatic and zenit, not ready to pay $350 right now.
Mazurka said:
You can always buy inexpensive M42 adapters for most SLRs.
The key word is 'most'. The only other SLR system I have and interested in is Nikon F mount. Unfortunately, adapter for this SLR is either expensive or you loss focusing scale and infinity (kind of micro ring); or you get really cheap compensating lens compromising quality of m42 lens - which doesn't make sense at all.
Eduard.
If you're only interested in Nikon, then it makes no difference to you whether the Bessaflex is discontinued.
If your "other SLR" is a Bessaflex or any other M42 body, you're already covered.
If you must buy an M42 camera, Stephen still has a few Bessaflex available. Otherwise, there are always tons of Spotmatics, Fujicas, Prakticas, etc out there.
So everything does make sense after all. :D
In retrospect, it seems now that the only real difference between the Bessaflex and my Spotmatics was the brighter viewfinder, LED metering, and the little window in the door.
I believe the build quality of the Pentax bodies is superior. Mine were made in the late sixties/early seventies and they remain rock-solid.
Yep. Welcome to the age of the 3-year-old cycle. Consume, consume!! Things that last are bad for bidness. But that's only for a 6-month fiscal plan. :mad:
Hold on to your Spotmatic, dearly. :(
If you use flash with any lens longer than 50mm or in daylight as fill, you'd be grateful for the 1/125 maximum X-sync speed like that on the Bessaflex (compared with 1/60 on the Spotmatics).
Mazurka. You are right. I had forgotten about that for the simple reason that I never use flash (except in studio). I no doubt skipped the flash section in the manual when I got the camera.
