Best battery choice for the Konica Auto S2
Stuart Lloyd
6:07 AM
I tried using the Weincell Zinc air option and that cost me £6 and lasted two months and about four or five films. I know the silver oxide option is supposed to be pretty good although at 1.55v you have to adjust the ASA. Just wondered what other members choose to do and which option they found worked best?
I still have some mercury 1.35V beasts (SR44-sized to use with O-ring) but also use SR44 with diode in some devices, designed for mecury batteries. My KAS2 haven't been cleaned perfectly (shuuter), so A mode isn't working, only manual and there I go without battery.
If the SR44 size works, I'd say just use those and adjust the film speed accordingly. If you don't want to adjust film speed, then get 675 size zinc-air batteries at any pharmacy (chemist?) -- they are the same thing as the Wein cells, though not as long lasting. However, they are a lot less expensive.
I use inexpensive 675 hearing aid batteries in this inexpensive adapter:
http://www.paulbg.com/Nikon_F_meter_batteries.htm
If you remove the battery when not in use and cover the + side with the tab that comes with the battery, it will last several months. The batteries are inexpensive to begin with. This provides 1.4 volts and metering is accurate.
This combination is also good in my Minolta Hi-matic 7S, Yashica Mat 124, and Minolta SRT201. It's a little too wide to fit in my Zeiss Ikon Contaflex Super BC.
