cameramanic
Following the light
I just got my first Fed 2 with Industar 26, from the bay.I have Jupiters 8,9,11,12 and Industars 22,61, what will be the best lens for everyday street photography ?
I am thinking Jupiter 12, or 8, or the collapsable Industar 22, you thoughts on this will be appretiated.
Regards
Cameramanic
Regards
Cameramanic
simonankor
Registered Addict
I like the Industar 61 for that extra bit of speed... but then... collapsible I22 is beautiful! I want to get one of those
I have to say though, the Canon 50mm f/1.8 is rather nice (unless you dislike infinity locks)
cbass
Nutmegger
Probably the J12, even w/out an external finder. A collapsible lens like the I22 is easier to carry but will need to be extended for every use.
Have fun! Street shooting can be rewarding & healthy (it usually involves much walking).
darkkavenger
Massimiliano Mortillaro
I would hesitate between I-61 L/D and J-8// I-22 is beautiful but as previously said, you've got to get it out each time to use it
darkkavenger
of course I was forgetting the J-12!
captainslack
Five Goats Hunter
I can only comment on the I-26 which came with the camera. Great lens! Sharp and contrastly.
rbiemer
Unabashed Amateur
I like the way you said that!cameramanic said:I just got my first Fed 2 ....
Regards
Cameramanic
The J-9 and J-11 might be a bit long but I would start with something close to what you have used(focal length) before and then adjust from there as you need to. As far as the specific lenses you have--I own J-8, J-12, Industar 22, L/D 61 and like the look I get from all of them. The Industar 22 is slower than the others and, if it's the collapsable version, slightly slower to get ready. The FED 2 I owned came with an Industar 26 lens that I also liked.
My most used lens, lately, is the 35mm J-12. After that one I am comfortable with any of the 50mm lenses, though each has their + and - .
I like the click stops for the aperture on the I-61. I like the f2-f22 fange on the J-8.
I like the compactness of the I-22. I haven't got a lens hood yet for the I-22 so I have to be abit more thoughtful where I point it(to keep flare to a minimum). All the others I use the same slip-on plastic hood for so flare is not so much of a worry with those. That hood vignettes slightly on my J-12 but it hasn't been a major problem so far as I tend to frame loosely and then crop the print after.
Rob
iggers
Question: Stopped down to, say, f/4, does any of these lenses - J8, I-22, I-26. I-50 or I-61 L/D - stand out as superior to the others?
GeneW
One thing I always notice is the excellent bokeh I see in J8 images when used in the f/4-5.6 range.
Gene
Gene
kiev4a
Jupiter 12 is the best all-around lens for almost any FSU camera, IMHO
iggers
Jupiter 12
Jupiter 12
I must be doing something wrong. I've never had good results with my J-12.
Jupiter 12
kiev4a said:Jupiter 12 is the best all-around lens for almost any FSU camera, IMHO
R
Roman
Guest
I also love my J-12, and both the I-61 and J-8 are great lenses - but with very different footprints: the I-61 is perfect for gritty, high-contrast, sharp slice-of-life pics, the J-8 is better for pleasing, lower contrast, smooth, beautiful pics.
Roman
Roman
DaveP
I would have to go with the J-8 as overall best to use. The I-22 is great but you have to pull the filter on and off too many times to changethe f stop.
kmack
do your job, then let go
For the way I work with film I have to vote for the J-12, with the I-61 a close second followed by the J-8.
cameramanic
Following the light
Thanks for the input guys, I will try all the lenses and compere the results
Regards
Cameramanic
Regards
Cameramanic
wyk_penguin
J-12 for street shooting and J-9 when you see a nice & willing candid of the opposite sex, the I-22 may become a nuisance, but if you don't use filters...
John Robertson
For street work the J12 would be good, I will guarantee that if you use the collapsible 50 , at some point in the heat of the moment in street photography you will forget to extend it!!
fotosniper
Fotosniper
For street-shooting...35 mm J12 is the one for me...good depth of field..try for F8..400 speed film..set lens to hyperfocal distance and forget the ragefinder..just blast away!..
you can get real sneaky and hold it waistlevel..as if checking the controls..snigger..snigger!
try it..see what you get!
fotosniper
Fotosniper
that was an apt typo..RAGEFINDER!!!....gonna use that from now on!...
John Robertson
try it..see what you get![/QUOTE]
Probably a punch on the nose!! Or in UK , if children happen to be in the field of view, arrested!!
