Best lenses for Pen F/FT?
The size of a 4/3 sensor is 13x17.3mm. The size of a Pen F negative is 18x24mm. Even if someone would make an adapter the lenses of the 4/3 world not work for half-frame negatives.
Further, as to µ4/3 lenses, I was surprised to see in Photozone.de tests that these lenses often/generally have severe optical defects that are automatically "corrected" using the camera's lens database and processor. Likely less expensive to deal with distortion and fall-off this way than by correcting these issues in building the lens. Already we've seen some of this on a lesser scale in other digital cameras, even including the Leica M8/M9.
Reminds me of win-modems. Modems that fail unless corrected under windows. The wave of the future - raw crap in and sort it out in post process by the CPU. gads
CD-, DVD-, Blu-ray- and anything-else players do the same thing. The most important element in that technology is error correction.
Even the Hasselblad H3 series uses software correction for at least one Zeiss wide-angle lens. Zeiss just made a lens without compromises except one or two parameters. These are completely corrected by software. The result is the best of both worlds.
In cheap cameras, of course, the manufacturers just put some heavy makeup on the results of their cheap lenses.
Just ran a roll with a few 60/1.5 shots.
One for the season as long as it's posted:
