sojournerphoto
A 5D1 is capable of resolving around 11.5 stops of dynamic range in the right conditions. Obviously getting the best from it requires some careful technique. Getting exposure right is critical to avoid burning highlights beyond recovery. The 1Ds3 is similar and I would expect the 5D2 to be pretty much the same, maybe edging towards 12 stops. How you deal with this in printing is another matter.
Bit depth in raw is directly related to dynamic range as raw capture is linear data (unlike jpgs which have a gamma curve encoded in the colour space so dynamic range is not determined directly by bit depth). However, although 14 bits is capable of covering 14 stops of range, the noise floor limits the useable dynamic range to somewhat less than the bit depth would otherwise allow. But to knock an old tale on the head - raw bit depth does not describe the number/size of steps on a same size staircase - it gives you many smaller stairs and allows you to take several smaller steps in place of the first step on a courser staircase, which is to say it expands the dynamic range (as noted noise floor considerations aside!).
Whatever, nice camera.
Mike
Mike
