Braun F900 Pro Flash Unit Charger
Creagerj
Incidental Artist
4:11 AM
I came across an ancient beast of a flash for just a few bucks this weekend at a thrift store and decided to buy it. Unfortunately the NiCads are dead, and even worse, there is no charger. Dead batteries I could probably find a replacement for, but the charger is another issue. I've searched high and low on google and haven't been able to come up with anyone selling a charger.
Does anyone have any experience with these units and have any idea about how I might be able to get it up and running again? I'd be willing to DIY since I didn't really pay that much for it.
hi joe
i have the F800 flash, and replaced the batteries with enough rechargable cells to equal the original voltage. i have the original charger, but you should be able to use a generic charger with the right capacity. the flash is a good one when it's up and running, with narrow, wide angle and full or half charge to give you a range of f-stops. if you need a second lamp unit, maybe i can unearth one here.
good luck
rick
hi joe
good luck
rick
When you say enough rechargeable cells do you mean that you used standard "C" cell rechargeable batteries that you remove and charge in a battery charger, or did you rig up a new battery pack and use something like a car charger to charge the batteries?
I appreciate your help and yes I think I would be interested in a second lamp if I can get this battery pack working working.
I do have one of these beasts since 1977. I brought it from East Africa in 1985 and it is in working condition, with a leather case for the power pack, as well as the charger. Works well. Am trying to sell it.
Zahir
sorry joe
i didn't see your question or other posts and thought the thread had died.
yes, i used rechargable nicad battery cells (c or d, whichever fit) and wired them to get the correct voltage. i charged the flash with the standard braun charger.
i've also seen some sealed lead acid batteries which might be interesting. there was a lead-acid pack available as a factory option.
i'll open the box and see if i have a spare lamp head.
regards
rick
I do have a Braun F900 in full working condition since 1977, with the power pack, charger and leather case for the power pack. Trying to sell this beast. I am in Toronto.
Zahir
