Godfrey
somewhat colored
It's the settings and menus that bug me with the OMD.
I go from landscapes, to street Photography to birds in flight, cars at speed. I don't use the camera every day, and my simple mind makes changes. Then I wish I hadn't!
This is a common complaint with Olympus cameras. They take the strategy with their higher end cameras that the buyers are sophisticated and want a bunch of features, will learn how to sort them out for their use. By and large the menu structures are logical but it takes time and effort to learn the logic and 'get it' so that it becomes natural.
If you regularly use a few different camera setups optimized for your subject at hand, go to Page 42 in the manual and learn about using MySet custom configurations. You can define up to four custom configurations for your various uses and recall them to active, or reset the camera to its defaults, with the MySet facility. The advantage to this is that you can have four "starting points" stored, pick one, use it, modify it, and then return to it without batting an eye. Saves having to re-figure what you changed and modified everytime you get lost.
I've used this sort of facility on my Olympus, Leica, Panasonic, and Ricoh cameras. It's very handy when you get the hang of it.
Perhaps the problem is that I must be a technophobe. What happened to understanding light, setting ASA, aperture and shutter speed?
Understanding light, sensitivity, aperture, and shutter speed are all still there. Configure the camera to put those controls up front for direct access, create a custom config to store that configuration, and be happy. The first, and often the only, custom config I make for any camera is setup for aperture priority, center-weighted averaging meter pattern, direct control of aperture, exposure compensation, and ISO. I map any function that allows me to toggle AF/MF in a single button press to a convenient button, same for AE-Lock. That's how I shoot 99% of the time. When I've shifted the configuration of the camera to other things and forgotten all the details, I just load that config again.
Makes life simple. 🙂
G
(My alternative login should be "way2mnycameras" ... :-\)
