Dan,
really unless you are really keen for some reason to use your particular 127 brownie camera, its not a great way to go, not economical for you at all. fiddly and time consuming to cut 120 film down to fit and expensive to buy 127 film, to use for say a brownie camera e.g for not much more, or around the same price it would cost you to buy a roll of 127 film, you could purchase a 120 film brownie camera.
120 and 620 film are the same size as each other but different to 127, which was in essance a miniture format film, bigger but more comparable to 35mm in some ways.
Dan,
Yes, 120 film does have a paper backing. In fact, the numbering for the red-windowed cameras is the same also. As far as I know, the only difference between 620 and 120 is the spool size.
Sometimes, you can fit the roll of 120 in a 620 camera and wind it onto the 620 spool.
Randy
Hi Randy,
That simplifies things quite a bit. I can handle the respooling (from 120 reel to 620 reel).
This doesn't sound too bad after all.
Hi Randy,
Thanks, ZorkiKat.
What about 620 film?
Or more to the point, what kind of film do you guys use?
620 film is the same film as 120, just on a skinnier spool. B&H sells Efke film in 127 format. They also sell film in 620 format. It isn't much more expensive than 120 or 620, but you can't get it at Walmart.
actually that Efke isnt that bad a price is it ($4.95), about 25% more than 120 film. B&H shipping to AU is a killer though. There was a guy recently selling 127 film on ebay for rediculous high prices... quick look at freestyle shows they have the Efke as well for a few cents cheaper ($4.39)
Thanks to all for Brownie advice.
I received a Brownie Hawkeye today (from the *bay), and it's beautiful. I've already given it a CLA (well, actually, just a C-- I didn't do any L or A). Mainly to clean up the grime from lens and rangefinder surfaces. It looks pretty good now.
I also loaded a roll of Tmax-100 into it. It's just 120 film, and it loaded fine. The camera came with a 620 take-up reel, and I think that's all I need (as long as I don't lose it). I plan on processing my own B&W, so that shouldn't be a problem. (I do need a 120 film reel for the developer tank, but that should be easy.) I can't wait for daylight, so I can shoot some lo-tech MF. The camera also came with flash attachment, so I'm in the market for flash bulbs. (Wonder if a strobe would work?)
You're probably going to need to clean the shutter blades and escapements too. Set your shutter for 1 second, look at the second hand on your watch, and trip the shutter. It is probably way off, and that means it is a cinch the other speeds are too. Fortunately, it is an easy fix.
If I remember it right, Brownie Hawkeyes came with simple rotary shutters. 2 speed settings- I and B(T?). "I" stood for instantaneous, where the shutter run at a nominal value between 1/25 to 1/40 sec. "B" (or T, for time) would have the shutter open for as long as the release was tripped. No slow or fast instantaneous speeds. 1 sec would be done by setting the shutter on T and holding the tripper down for 1 sec.
Some Brownies don't even have the T/B setting. Just a single snapshot shutter setting.
The shutter mechanism is a relatively simple affair. Not much escapements there. No gears, just levers with springs pulling or pushing things around. Just a fan-shaped blade (single) with an elongated hole which passes over the aperture. This blade is attached on a pivot (this is where the oil would go) and pulled back and forth, powered by a stretched coiled spring. No cocking is needed- the shutter was 'self-setting'.
Or was there a Hawkeye which had a more sophisticated shutter?
I have an old brownie box camera that won't take 120 on either spool, so I've taken a file to an old 120 spool. It only takes a few minutes to work it down to size.
Now I need to file down a roll with film on and shoot.
