nzeeman
maybe you should go with that 35/2.5 skopar because it has very good price. but if you need more speed - you can find used ultron 35/1.7 for around 300$ i think - or nokton 50/1.5...
I have a meter and rarely ever use it. It's just one more thing to carry. :-D I like to think of my umetered cameras as a chance to get to basics and practice sunny 16. Just the barnack and collapsible lens.
I highly recommend you just pop the $40 to get an industar 22 (50/3.5) while you wait for 'the lens'. It fits a niche (elmar) that you will want to fill someday. It's cheap, sharp, and small. For the money, it's one of the best purchases I have made. And if you shoot 3200, you might not miss the speed so much.
DON'T be tempted to try to set the frame-lines manually as this is a real pain in the bum with an M-series. Yes, some do it, and some even wedge the frame selector lever. but it's hellish inconvenient and pretty much negates the advantage of owning an M.
Reports vary widely about adapter rings. They're not inherently difficult to make but apparently some manufacturers are quite sloppy. Again, economisibg too far on these things is a bit like buying a modern racing motorcycle and putting 1960s East German tyres on it.
Roger
I guess I should just buy a 50mm ring to get the proper framelines for now as when I get a decent 35mm it might be M mount anyways.
One thing that hasn't been mentioned is the decision to go 35mm or 50mm, both have their devotees that can give you telling (or repelling) arguments for their choice 🙂
I'm on the 35mm camp, so in your place, my choice would've been either the Skopar or save a bit and get the Ultron. Both CV, both good.
