DNG
Film Friendly
I going to try my 1st roll of XP2 that can be rated from 50 - 800 according to the fact sheet.
Since, with C41, there are no adjusted development times (and is recommended NOT to adjust the development, just shoot at the ISO you need)....
So, the Question
Should I mix ISO's on the same roll?
Has anyone done this?
Did you like the results?
Did it make any difference?
Gut says, I should have no problem mixing ISO's on the same roll, since C41 is a set time for all ISO settings.
So, the Question
