Lauffray
Invisible Cities
All great suggestions folks, thanks a lot.
A Pelican case (nor any other case) will not allow you to take photographs. They just protect during transportation. Get the proper tool for the task, Nikonos perhaps or Aqua Snappy, and enjoy the ride.
I guided in the San Juan islands for years.
Make sure you have a longer FL lens with you. The typical RF outfit will leave you unsatisfied with your reach on many occasions.
Pelicans are fine for transport but leave much to be desired as far as access goes.
Who wants a Pelican in the cockpit while paddling?
I used a roll top dry-bag with a MJUii for close in and a 70-210mm SLR/DSLR.
I will ! Do you think if the o rings aren't top shape that it would matter for my intended use ? Both people I consulted said that if there's no pressure, that is, if I'm not actually underwater, then it should be ok. (I'll be in a kayak, possibly lots of waves, spray, wet hands etc)
Guys, I got this this morning 😀
I checked the o rings then passed by a store after to have it checked again, the flash connector o ring seems a bit flat, but since I'm not exactly diving with it I think it should be ok. I'll replace the o rings when I get back.
150$, I think it was a good deal
You have excellent taste! 😉
Chris
+1 on the tele.
About tethering camera to boat and /or roll top bag in cockpit. All fine on flat water, a couple of surf landings will show you the error here.
As the OP states that it will be on calm water all this might be ok but weather changes and tides can make a flat bay very interesting.
As a disclaimer, I have been involved to much in training and incident management lately so my views are a bit distorted. But whatever you do activity or camera wise plan for a worst case scenario, in your case this might only be falling in.
