Can water logged undeveloped film be processed?
bigdog
3:30 PM
Maine, USA
I was canoeing with the son and wife yesterday and when I took the canoe out of the water my 15 year old Ricoh point and shoot took a bath. Can a roll of undeveloped film that has been soaked in lake water be processed? Is the camera toast?
There's no way you're going to be able to load this film onto a reel as Toby said. You'll have to process this film in a tray or tank in total darkness. This won't be very much fun.
Never done this before, but if I was faced with your situation I'd load the film in a darkened bathroom. I would presoak the film canister in clean sink water and then load the reel in or over the sink. Rinse it gently a few times by submersing it in and out of clean water and there's a good chance it will develop the same as with a water pre-soak. I always pre-soak T-Max in a water bath and many people pre-soak other B&W film. Good luck -- keep us posted 🙂.
I've never tried loading totally wet film onto a reel, but even slightly moist film won't load because it gets sticky. (I'm talking plastic reels.)
You didn't say whether it's E6, C41 or B&W. If it's B&W, you'll be fine, just do what Manolo and Frank said. If it's C41, you should take it to the lab ASAP and tell them what happened. If it's E6...well, in nomine Pater...
Can't hurt to give it a try..
While vising Toronto this summer, I decided to keep all of my exposed 120 film in plastic ziploc bags and placed within a cooler full of ice.. the thought being to keep them cool.. well, ziploc bags are NOT water tight... :bang:
Several of the ziploc bags, filled with film, slipped into the ice cool water... the film got wet.. No way to tell how wet, but it did not look good..
I checked several websites for opinions on processing/handling wet film. My choices came down to express shipping the film to my friendly local processor in the states or finding a lab in the TO area that would process film that had been submerged.. Since I wasn't sure how much of the film was submerged, I did not want to risk damaging undamaged film by keeping it wet...
I called the very nice people at KornerColor lab ( on Bay and Bloor ).. They initally stated that they would not process the film because it would corrupt their chemicals, but I was able to get them to accept the film.. They were able to process all 18 rolls successfully..
In the future, I will not place film into cooler full of ice..
Manolo Gozales said:
Hey🙂
If you are using stainless steel reels, you can load the film on while it is wet. So you could soak the film in clean water in a tray/sink to unstickify it (in the dark of course) and then load it on to the S/S spiral.
ManGo
That's a big advantage os SS reels. Shouldn't be a problem to load wet film (if you are familiar with that type of reel. Plastic reels? Forget it.
Loading wet film is no problem at all.
Stainless steel reels do not care if the film is wet or not. Load away.
Plastic reels are a bit more difficult, but not impossible. In a darkroom, immerse the plastic reel and film... have both under water either in a sink or in a bucket. With the whole thing under water, you will find the film 'walks' onto the plastic reel just fine.
Tom
As someone asked above, is it color film or BW? If BW, you shouldn';t have a problem. Just soak the film in a darktank in water for a few minutes to clear away algae, fish bones or other detritus from the lake. Then give it a go.
If color....I have no idea.
Chris
canonetc
