canon 110ed 20 battery cap
Davham
5:33 PM
Toronto, ON
I came across the above mentioned camera and it turns out to be missing the battery cap. Would one from the Canon 110ed fit, or is there some other solution I might try. It's in good condition otherwise
Thanks
David
I don't have an answer for you, since I had never heard of the Canon 110ED 20 before seeing your post, but after doing a little research I want to get one to add to my little 110 collection. It doesn't seem like it would be a risk to buy a cheap 110E to see if its battery cover might work. Give it a try, and let us know what you find out.
Scott
David--I have a Canon 110ED20, 110ED, and 110E. The battery caps are the same on the ED and ED20; however, the E cap is different and does not fit the other two models. Further, it is my evaluation that the E cap could NOT be modified to fit the other models. Best of luck in finding a cap.
