jlw
Rangefinder camera pedant
I would very likely dislike having freeplay in the focus ring and so I better go for a brass earlier model. Thanks for that tip and to all of you for the information above.
Maybe so, but if possible, try a late one first before you make up your mind. The radial play I meant is usually barely perceptible at worst (fractions of a degree) and many people don't notice it at all. It seems to be more common on the 50/1.4 than on the 50/1.8, also; I've got a 50/1.8 on which I can't feel it at all, a 50/1.4 on which it's barely perceptible, and another 1.4 on which it's a bit more perceptible but not bothersome (to me, at least.) It probably depends on how much use the individual lens has had.
The only reason I mentioned it was that I corresponded with someone who was disturbed by it (on a 50/1.4) and wanted to know if there was any way to fix it (which I don't think there is, short of maybe splitting the guide block and inserting a setscrew to make it a bit wider, eliminating the play.)
