swoop
How did you manage to get such precise framing using two different cameras one after the other?
I'm just that good. =)
lol. It took about 3 or 4 tries, but I used one, had the other in my lap and then quickly switched. Sitting in my chair across the room and kept the center on Emma's face. Using the center focus point on the 5D, and the rangefinder patch with the M9. Not too hard.
I think some of you may be right where Lightroom is reading the RAW file weird. Or doesn't know how to interpret the M9 file, as in there is no preset. It makes sense. Seeing as the white balance was set manually. So it should be the same but obviously isn't. I guess I need to just figure out how to make a preset.
Someone also noted that the M9 noise is "ugly." I'm not bothered by it much here. But it is slightly more visible. But I don't think it's that drastic. And it won't even be noticeable once the image is printed. Also note that in camera noise reduction on the 5D was turned off since the M9 also lacks noise reduction in camera.
It seems obvious though that the 5D gives a better image "out of the box" but the M9 is a lot more fun to work with.
I'll be trying the same comparison again in daylight.
