What's the AE-1p like? it has no aperture priority mode, right? Does the metering change along with the aperture ring movement? I've never used one, but might consider it since I have two FD lenses
The AE-1 Program has a shutter priority mode, a program mode and manual mode.
Mine is a real beater - before my time it obviously suffered a serious knock which has bent the rewind lever and shaft so it's somewhat off-kilter. Nonetheless, the camera continues to work correctly, albeit with rather rough film advance and rewind. It's obviously a tough and well-constructed thing.
But I don't use mine all that much. Partly because of said roughness, but mostly because I don't much like shutter-priority auto. When I have used it, it's mostly been in manual mode where I set the aperture (on the lens ring) to what I want, then adjust the shutter speed until the meter reading shows the aperture I've selected (or a stop or so over or under if that's what I want). I'd
prefer the meter to show shutter speed rather than aperture, and I'd prefer Av mode over Tv mode - but that's not on offer with this camera.
When I do use it in auto, I do so in program mode (and have to remind myself to set the aperture ring to the auto position as well as the shutter dial). If I
don't set the aperture ring to the auto position (but do set the shutter to auto) then program mode (which the camera thinks it's in) will set the shutter speed based on what it "thinks" the aperture will be, but the actual aperture used is what's set on the lens. This is not a great way to achieve correct exposure. Which is why I tend to use my A-1 or New F-1.
...Mike
