Canon LTM Canon IVsb Shutter speeds OK, dial off
Derek Leath
dl__images Instagram
2:44 PM
Hello all.
I came across a IVsb and the shutter speeds seem fine, but the dial is off by two places.
500 is bulb 1000 is 25.
If I take the dial off, would I be able to re-align?
thanks
Yes the dial is adjustable. Just cock your shutter, loosen the set screw(s) on the shutter speed dial and turn to the correct speed you think it should be.
Nathan
Possibly originally caused by adjusting the shutter speed without first cocking the shutter?????? I think I had something of this sort happen to me due to my absent mindedness on one occasion.
1/1000th sec Dial a little higher than the rest.
My IVsb shutter dial sits (or clicks into every place), but on 1000 it sits a bit higher. still works, but wondering if it should click into the slot?
Thanks
Thanks
No, the shutter speed dial should rest a bit higher when set to 1/1000. Many old 35mm rangefinders with a horizontal focal plane shutter are like this (don't ask me why).
Jim B.
